* * * * * 2 Голосов
Виды комплектаций, специальных серий и моторов
Сообщений в теме: 308
#1 Cherry Fox
Cherry Fox
    Забанен ибо задолбал всех
Отправлено 20 August 2006 - 16:47 PM
:arrow: MKII Комплектации:
* C
* CL
* GL 1984-1991
* GLX 1984
* GT
* GTD
* GTI
:arrow: Специальные серии (по годам выхода):
* Carat 1984-1986
* Match 1985
* Hit 1986
* Fun 1986
* Flair 1986
* Syncro 1986
* Pikes Peak 1986-1987
* Bistro 1987
* Memphis 1987
* Sky 1987
* Special 1987-1991
* Berlin Golf 1987
* Tour 1988
* Manhattan 1988
* Champion 1988
* 10 Million 1988
* Öko Golf 1989-1992
* Atlanta 1989
* Boston 1989
* City Stromer 1989
* Edition One 1989-1991
* Limited 1989
* Rallye 1989
* Black Line - Red Line 1990
* Country 1990
* Country Allround 1990
* Country Chrompaket 1990
* Fire and Ice 1990
* Madison 1990
* Moda 1990
* Quadriga 1990
* G60 1990-1991
* G60 Syncro 1991
* Pasadena 1991
* Function 1991
* Edition Blue 1991
* Barcelona 1991
:arrow: Моторы "НЕ GTi"
* Golf II: 1,8l 8V 66 kW / 90 PS Fuel Injected (RP)
* Golf II: 1,3l 8V 40 kW / 55 PS Digijet-Fuel Injector (NZ)
* Golf II: 1,3l 8V 40 kW / 55 PS Carburetor (MH,2G,HK)
* Golf II: 1,6l 8V 51 kW / 70 PS Carburetor (PN)
* Golf II: 1,6l 8V 53 kW / 72 PS Carburetor (RF)
* Golf II: 1,6l 8V 55 kW / 75 PS Carburetor (EZ)
* Golf II: 1,8l 8V 66 kW / 90 PS Carburetor (GX)
* Golf II: 1,6l 8V 59 kW / 80 PS TurboDiesel with LLK (RA,SB)
* Golf II: 1,6l 8V 51 kW / 70 PS TurboDiesel (JR)
* Golf II: 1,6l 8V 44 kW / 60 PS TurboDiesel with Oxi-Kat (1V)
:arrow: Моторы GTi
* Golf GTI: 1,8l 8V 79 kW / 107 PS (with Katalysator PF)
* Golf GTI: 1,8l 8V 79 kW / 107 PS (with Katalysator RD)
* Golf GTI: 1,8l 8V 82 kW / 112 PS (No Katalysator EV)
* Golf GTI 16V: 1,8l 16V 95 kW / 129 (with Katalysator PL)
* Golf GTI 16V: 1,8l 16V 102 kW / 139 PS (No Katalysator KR)
* Golf GTI G60: 1,8l 118 kW / 160 PS (with Katalysator and G-Lader PG)
* Golf Rallye G60: 1,8l 118 kW / 160 PS (with US-(Bi)Katalysator, G-Lader and all wheel drive transmission Syncro MKB 1H), Limited to 5,000 pieces
* Golf Limited G60: 1,8l 16V G60 155 kW /210 PS (with Katalysator, G-Lader and all wheel drive transmission Syncro 3G), limited to 71 pieces, Price in 1989 68,500DM
#2 Nekto
Nekto
  • 1885 сообщений
  • Интересы:Резьба по моржовому клыку :)
Отправлено 20 August 2006 - 19:13 PM
Это конечно хорошо, но информации явно мало.
Например расписать чем отличаются комплектации.
Явно не все двигатели указаны.
Стоит доработать.
  • -1
#3 Cherry Fox
Cherry Fox
Отправлено 20 August 2006 - 20:06 PM
Млять! Доработай!!!
(Вот именно такие посты отбивают охоту делиться какой-либо информацией!)
#4 DJ Kill
DJ Kill
  • 4185 сообщений
Отправлено 20 August 2006 - 20:18 PM
Кому надо больше инфы - идет и переводит doppel-wobber.de
Там есть практически всё. :)
#5 БоБ
БоБ
    овощь и тошнот
  • 1059 сообщений
  • Интересы:mk2, фото, авиация 1/48
Отправлено 20 August 2006 - 23:01 PM
:arrow:  Моторы GTi
:shock: Епта, у меня оказывается GTiный движок. Я КРУТОЙ *drum* *brake*
#6 tu6kan
tu6kan
    Мангальер
  • 1121 сообщений
Отправлено 21 August 2006 - 08:29 AM
а моя комплектация CLi хде? :cry:
спасибо, Сереж, полезная инфа :)
#7 Cherry Fox
Cherry Fox
Отправлено 21 August 2006 - 13:55 PM
А у тебя, Тушкан- "тушкан"! И, видимо, не попадает под Европейские комплектации....
#8 OFNEN
OFNEN
    SYNCRO-вод Всея
  • 37296 сообщений
Отправлено 22 August 2006 - 00:04 AM
Моего мотора нет RH :roll:
#9 DoorWood
DoorWood
  • 686 сообщений
  • Интересы:VAG и его история, инжиниринг в теории, управляемость как искусство
Отправлено 22 August 2006 - 02:26 AM
Немного добавлю и исправлю:
* Golf II: 1,8l 8V 66 kW / 90 PS Carburetor 2E2 (GU)
* Golf II: 1,8l 8V 62 kW / 85 PS Carburetor 2E2 (with Katalysator RH)
* Golf II: 1,8l 8V 66 kW / 90 PS K-/KE-Jetronic (GX)
* Golf GTI: 1,8l 8V 82 kW / 112 PS Digifant (PB)
#10 БоБ
БоБ
    овощь и тошнот
  • 1059 сообщений
Отправлено 22 August 2006 - 09:47 AM
Инфа с www.doppel-wobber.de
Базовая комплектация (1983 - 1988)
Внешнее оборудование
Многослойное ветровое стекло
пластиковый бампер
Галогеновый головной свет
Задние фонари
Передний спойлер
каналы для стока воды на крыше
Cavity preservation
Continuous underbody protection
Wheel housing bowls in front
Колесные диски с отверстиями
black grasp border на задней двери (наверна накладка вокруг замка)
Интерьер
umschaumtes безопасное рулевое колесо
Складной механизм передних седений
Регулируемые подголовники передних седений
apportionable back bank
Трехточечный автоматический ремень безопасности
Lap belt in the back (center)
Shaped part sky
Подсветка печки
Обогрев лобового стекла
Плафон в салоне
Защитное устройиство для детей сзади (х.з. может это замок от детей)
Ниши у водители и пасажира спереди
Бардачек
Munzspeicher on frame tunnels
Пепельницы спереди и сзади
Ручки с крючками для одежды
Двери и cowls
disguised Fensterbrustungen
Обивка потолка
Обивка пола
Обивка пола в багажнике
Обивка багажника
Место с легким доступом к аварийному треугольнику и аптечке
Функциональное бобрудование
Дворник и омыватель задней двери
Каленое заднее стекло
Gas pressure absorber at back window
Задние противотуманки
Габаритный огни
Two-stage circuit disk wiping plant with tapping AUTOMATIC
Дворники на лобовом стекле
Запираемая крышка бензобака
Козырьки от солнца
Антибликовое зеркало
Настраиваемый instrument lights
Приборная панель с: тахометром, обометром, индикатором температуры антифриза;
Контрольные лампы генератора, давления масла, поворотники, high beam(наверно дальний свет),
предварительного прогрева (на дизелях)
Контрольная лампа ручника
Hazard warning flasher
Трех скоростная вентиляция с воздуховодами для ног передних пассажиров...
продолжение следует...
#11 БоБ
БоБ
    овощь и тошнот
  • 1059 сообщений
Отправлено 22 August 2006 - 10:05 AM
C (1984 - 1986)
Защита задних колесных арок от камней
Черные колпаки на колеса (black covers for wheel hubs and - screw )
Нету правого зеркала заднего вида
Интерьер
Две ниши в торпеде
Пространство пола покрыто обивочным материалом
Material coverings
Обивки на дверях и cowls
Опции за доп. оплату
Sun roof with setting up draft deflector
becomes green thermic protection glazing (тонировка чтоли)
Externalreflect on front seat passenger side
Цвета металлик
Особые цвета
#12 Cherry Fox
Cherry Fox
Отправлено 22 August 2006 - 19:47 PM
Офигеть! Люди нашли ДоппельВоббер и научились пользоваться транслейт.ру! :lol:
#13 DJ Kill
DJ Kill
  • 4185 сообщений
Отправлено 22 August 2006 - 22:23 PM
Дык два дня прошло. :) :D
#14 Nekto
Nekto
  • 1885 сообщений
Отправлено 22 August 2006 - 22:34 PM
Там тоже не все есть. Хотел про CL посмотреть, а нету :(
#15 Cherry Fox
Cherry Fox
Отправлено 22 August 2006 - 22:35 PM
Ну так ты найди и сюда выложи, дабы народ просветить!
#16 Nekto
Nekto
  • 1885 сообщений
Отправлено 22 August 2006 - 22:42 PM
Так и сделаю. Только найти правильную информацию совсем не просто.
#17 Cherry Fox
Cherry Fox
Отправлено 22 August 2006 - 22:43 PM
Вот ты бы мне и сказал "спасибо" хоть за ту инфу, что я нашел, а не исходился бы....
#18 Nekto
Nekto
  • 1885 сообщений
Отправлено 22 August 2006 - 22:54 PM
А я как-бы и сказал :D - "Это конечно хорошо". По моему это означает положительную оценку усилий. Просто было интересно как раз по комплектациям расклад посмотреть, вот и расстроился немного. Похоже у меня гольф нестандартный какой-то по салону - из кожи молодого дермантина :D Думал посмотреть - бывает такой салон на CL или нет.....
#19 DJ Kill
DJ Kill
  • 4185 сообщений
Отправлено 22 August 2006 - 23:05 PM
Граждане, не стоит забывать, что "комплектация" - это только маркетинговый ход.
То есть есть гольф 2. Есть к нему набор опций (кожа там, кондей, подогрев сидений, цвет ковриков в салоне). Иногда устраивают "распродажу" - делают фиксированный набор опций по фиксированной цене.
Соответсвенно, многие ваши (и моя) комплектации - это не заводские. Это диллерские. То есть диллер набрал неких опций и впаривает их оптом называя неким именем.
Плюс к этому покупатель-немец мог к этому набору опций за доп бабло добавить что-то для себя. Так мог появится, допустим, гольф 2 в самой чахлой комплектации (ну не важен Гансу был кондей и мощный мотор), но с кожанным салоном (Ганс балдел от кожи, байкером был).
Так что если вы не нашли свою комплектацию на Доппел-Воббере, то это скорее всего значит что некий диллер "автохаусАГ" придумал её сам, а некий Ганс её дополнил на свой вкус.
#20 БоБ
БоБ
    овощь и тошнот
  • 1059 сообщений
Отправлено 23 August 2006 - 09:03 AM
Я все перевожу вручную!!! А про доппель узнал только в пятницу.
