Handmade Pin extactor tool
Сообщений в теме: 21
#1 e404
Отправлено 20 August 2012 - 13:32 PM
Рыл нет на предмет дешевых пин-экстраторов для разборки разъемов.
Вот на что наткнулся на сайте бмв-водов за бугром ;)))
Переводить влом... копипаст будет как есть %)
first, start with the aforementioned straw. cut a lengthwise slit at the end, 3/4" to 1" in length.
trim some of the straw by cutting another lengthwise slit.
remove the trimmed portion.
insert the trimmed straw into the connector by compressing the straw end to size - if you trimmed the straw enough, you should be able to squeeze it down to the size of the pin w/o much if any of the straw's wall overlapping where the slit is. you must wedge the straw BETWEEN the outside of the metal pin and the plastic plug body. be sure the straw does not go inside the hollow metal pin - that won't do anything.
press wire and straw firmly inwards to engage the pin's fingers.
after straw will not insert further, extract the pin by pulling on wire. a firm tug may be needed, but do not use excessive force.
if the wire does not come out, the straw may have not seated properly - start over with a clean end and try trimming more off the straw and/or using a thinner straw. however do not trim too much off the straw - there should still be enough in its circumference to cover the 4 fingers of the pin without overlapping excessively.
that's it. in the illustrations i show the connector that comes with the iPod harness, but the same procedure will work with the larger radio harness.
пруф
Сообщение отредактировал e404: 21 September 2012 - 13:25 PM
#2 e404
Отправлено 21 September 2012 - 13:35 PM
Продолжаем тему изготовления экстракторов для разъемов ;)))
Думаю не нужно рассказывать, что инструмент для разборки разъемов не дешев и не везде доступен в продаже.
Рылся на ибее и наткнулся на такой вариант инструмента для разборки разъемов на всякие там датчики г2 (и подобных):
Как видим очень легко изготовить самому :)
Далее на работе на участке сборки у пацанов углядел разноширокие пинцеты и вспомнил экстрактор с картинки :D:D:D
Вечером зарулил в магаз и купил такой пинцетик:
Немного поколдовал у точила и вот результат:
#3 Ветер
Ветер
    ништяков много не бывает
  • 4762 сообщений
  • Интересы:mk2, Урал М-62
Отправлено 21 September 2012 - 13:40 PM
цена пинцета?
первый способ достаточно изобретателен, только надо брать трубочку коктейльную и он не будет работат на разъемах из второго поста.
#4 e404
Отправлено 21 September 2012 - 13:41 PM
ну в моем контексте 200р
а так какой купишь, главное чтобы он был с мясистыми усами чтобы было чего стачивать
есть говнопинцеты из жести - такие не подойдут
#5 УлыбкиН
УлыбкиН
  • 836 сообщений
Отправлено 21 September 2012 - 13:42 PM
я украл у подруги обычную заколку для волос =) и готово
#6 e404
Отправлено 21 September 2012 - 13:51 PM
без фото не поверим ;)))
#7 УлыбкиН
УлыбкиН
  • 836 сообщений
Отправлено 21 September 2012 - 13:55 PM
я когда на своём носке проводку делал. обычная заколка отлично подошла. там ведь главное поджать фиксатор. можно и обычной булавкой. пассатижами откусить часть и готово =) подручных средств навалом ;)
#8 Tiburon
Tiburon
  • 1311 сообщений
Отправлено 28 April 2013 - 09:47 AM
Ничего у меня не получается с соломинкой =( Соломинки из IKEA слишком мягкие.
У кого-нибудь есть опыт/мысли/предложения чем еще можно достать клемму круглую?
#9 koncedalov
koncedalov
    это аватарка
  • 1371 сообщений
Отправлено 28 April 2013 - 16:46 PM
можно чем угодно достать, скрепкой, сверлом тоненьким, много чем. просто если использовать не специальный экстрактор, а всякие подручные средства, то приходится применять некую ловкость рук.
#10 Tiburon
Tiburon
  • 1311 сообщений
Отправлено 28 April 2013 - 23:25 PM
Тонкий пинцет и зубоврачебная "ковырялка" не помогли.Конструктив самой клеммы не известен,прижатие одной видимой защелки не спасает ситуацию.Сделаю фото,может так будет проще.
#11 Customizer
Customizer
  • 488 сообщений
Отправлено 28 April 2013 - 23:51 PM
использую доработанные невидимки для волос, на самом деле 70-80% разбирается одним екстрактором
ЗЫ: могу предоставить размеры каких угодно VAG-овских разпиновывателей и для какик разъемов их пользовать, поскольку тружусь на VAG
#12 Tiburon
Tiburon
  • 1311 сообщений
Отправлено 29 April 2013 - 00:30 AM
Мне для Porsche надо =(
#13 Customizer
Customizer
  • 488 сообщений
Отправлено 29 April 2013 - 00:35 AM
так всё равно ваг
#14 Tiburon
Tiburon
  • 1311 сообщений
Отправлено 29 April 2013 - 00:45 AM
Offtop
Очень много на 944,964 и 993 разьемов с трехлучевой звездой =)
#15 Customizer
Customizer
  • 488 сообщений
Отправлено 29 April 2013 - 00:49 AM
ну фотку бы хоть, пины позиционировать можно как угодно, сути не меняет
#16 e404
Отправлено 29 April 2013 - 07:37 AM
круглые пины скрепками и прочей муйней не достанешь - у них по 3-4 лапки, которые одновременно только круглым чем то и сдавливаются
соломинку надо брать от соков
#17 kandalf
Отправлено 29 April 2013 - 08:03 AM
У меня вышло вынуть с обратной стороны, раздраконив пин в хлам (благо запасной под обжим был). Но потратил на это полчаса, никому не посоветую.
#18 protasevich
protasevich
  • 1 сообщений
Отправлено 21 May 2013 - 09:35 AM
Подобрать по диаметру трубку/колено от телескопической антенны (от радиоприемника).
#19 DbIPKA
  • 6266 сообщений
Отправлено 21 May 2013 - 09:59 AM
Очень легко доставать пины из второго поста часовой отвёрткой из советского набора 4шт. Механизм выглядит так:
1) Выясняем с какой стороны стоит фиксатор
2) Засовываем отвёртку чтобы плоскость жала была параллельно плоскости фиксатора
3) Надавливаем на провод в стороны отвёртки.
4) Проворачиваем отвёртку по часовой или против часовой стрелки.
Я так почти всю проводку разобрал. Никакого геммороя вообще нету.
#20 e404
Отправлено 22 May 2013 - 10:44 AM
а если фиксаторов 2?
